Liquid Cooled
Perfection
Why Asetek is the CLC leader for quality and reliability:
- Helium Integrity Testing to ensure each individual cooler is virtually immune to leaks.
- Automated sub-assembly stations to enhance consistency.
- 100% trace-ability throughout our production process to provide valuable insight and feedback.
- Vacuum Precision Filling to ensure optimal liquid levels.
EVGA Closed Loop CPU Cooler
(CLC) 120/240/280/360
Liquid Cooled Performance
The EVGA CLC 120, 240, 280, and 360 LIQUID CPU Coolers have arrived. These new liquid coolers from EVGA give you incredible performance, low noise, robust software controls and RGB lighting.
Built To
Perform
New cooling block offers improved flowrate and heat transfer surface area for incredible cooling efficiency.
Sync with your
EVGA GeForce RTX/GTX
Graphics Card*
Link up your EVGA CLC cooler with select EVGA graphics cards, and match the colors directly from software. One button to control both RGB LED’s! Color profiles even save to firmware.
* Available on select graphics cards.
Sleeved
Tubing
Fully sleeved tubing from radiator to CPU block.
New EVGA
Fans
These fans are built for superior cooling and lower noise. The curved housing reduces noise level and unique blade design offers incredible cooling performance. Teflon Nano Bearings ensure a long lifespan.
EVGA Flow Control
Software
This EVGA software gives you full control over your EVGA CLC Liquid Cooler including, fanspeed/curve, RGB lighting, Pump Control, Profiles and more! Also, the fan settings and lighting save to firmware meaning you can set and forget. Now Available. Click Here To Download.
Adjustable
Pump and Fan speed
Set a custom pump and fan speed to fine tune your system for the best performance, or quietest operation possible.
Features
- Built in 360mm radiator and 3x 120mm fans help dissipate the heat keeping the CPU as cool as possible. Fan can also be swapped or customized.
- Teflon Nano Bearing in the fans reduce noise and increase lifespan, while the curved housing improves air flow through the radiator to limit vibration and noise.
- Variable controlled fans allow dynamic fan speed based on CPU temperature, and the water cooling efficiency means the fans can operate at a lower speed to reduce noise.
Specs
Waterblock
- Premium Retention parts for Intel LGA2066/2011/2011-v3/1150/1151/1155/1156/1366
- AMD retention ring for supporting AM2/AM3/AM4/AM5/FM1/FM2/TR4
- 100% Copper
- Fully controllable RGB LED
- Noise Level = 20dB(A) (MAX)
Radiator
- 396mm X 122mm X 28mm (LxWxH) (without Fans)
- 396mm X 122mm X 53mm (LxWxH) (with Fans Installed)
- Aluminum
Fan
- Size: 120 x 120 x 25mm (x3)
- Speed = 500-2400RPM
- Airflow = 74.82 CFM (MAX)
- Static Pressure = 4.04 mmAq (MAX)
- Noise Level = 16.0 dB(A) (MIN) – 39.9 dB(A) (MAX)
- Lifespan = 80,000 Hours
Warranty
- 5-Year Limited Warranty
Features
- Built in 280mm radiator and 2x 140mm fans help dissipate the heat keeping the CPU as cool as possible. Fan can also be swapped or customized.
Specs
Waterblock
- 100% Copper
Radiator
- 312mm X 139mm X 27mm (LxWxH)
- Aluminum
Fan
- Size: 140 x 140 x 25mm (x2)
- Speed = 600-2200RPM
- Airflow = 113.50 CFM (MAX)
- Static Pressure = 4.20 mmAq (MAX)
- Noise Level = 16.0 dB(A) (MIN) – 39.5 dB(A) (MAX)
Warranty
Features
- Built in 240mm radiator and 2x 120mm fans help dissipate the heat keeping the CPU as cool as possible. Fan can also be swapped or customized.
Specs
Waterblock
- 100% Copper
Radiator
- 276mm X 122mm X 28mm (LxWxH)
- Aluminum
Fan
- Size: 120 x 120 x 25mm (x2)
Warranty
Features
- Built in 120mm radiator and 120mm fan helps dissipate the heat keeping the CPU as cool as possible. Fan can also be swapped or customized
- Intelligent wiring system and smooth tubing makes this one sleek cooler without the messy wires
- Variable controlled fan allows dynamic fan speed based on coolant temperature, and the water cooling efficiency means the fan can operate at a lower speed to reduce noise.
Specs
Waterblock
- Premium Retention parts for Intel LGA2066/2011/2011-v3/115X/1366
- 100% Copper
Radiator
- 156mm X 122mm X 28mm (LxWxH)
- Aluminum
Fan
- Sleeve Bearing
- Speed = 1800RPM +/- 10%
- Airflow = 58.87 CFM (MAX)
- Static Pressure = 2.13 mmAq (MAX)
- Noise Level = 32.1 dB(A) (MAX)
Warranty
