The Next
Generation In Power
EVGA SuperNOVA G3
The next generation in power
EVGA SuperNOVA power supplies are well-known for their extreme efficiency, performance and reliability. In fact, over the last 3 years EVGA SuperNOVA power supplies have won over 70 awards from leading review sites. EVGA’s dedication to performance has forged the latest power supply platform: the EVGA SuperNOVA G3 Series. With these new power supplies, EVGA took the best features of the award-winning G2 lineup and made them even better. The SuperNOVA G3’s smaller size, improved performance and a new Hydraulic Dynamic Bearing fan give you ultra-quiet performance with an increased lifespan.
A reduced size does not mean reduced performance with the EVGA SuperNOVA G3 power supplies. At only 150mm long, this makes these some of the smallest power supplies on the market today, while offering improved performance and features.
Better performance, quieter operation and a longer lifespan.
Next-generation systems deserve next-generation performance. The EVGA SuperNOVA G3 takes the already efficient G2 series and makes it even better with improved efficiency and lower ripple. These power supplies are over 91% efficient!
Whisper Silent
EVGA ECO mode means the power supply is completely silent during low to medium loads. This is one quiet power supply!
Use only the cables you need, reducing cable clutter and improving case airflow.
World Leading
World leading warranty and support for 10 Years.
On 1000, 850, 750 G3 Models
World leading warranty and support for 7 years.
On 650 and 550 G3 ModelsProducts
Features
- Hydraulic Dynamic Bearing Fan for ultra-quiet operation and increased lifespan.
Specs
- OPP (Over Power Protection)
AC Input | 100 - 240 VAC, 15A, 50 - 60 Hz | ||||
83.3A | |||||
Output Power | 1000W @ +50C |
Features
Specs
849.6W | |||||
Output Power | 850W @ +50C |
Features
Specs
748.8W | |||||
Output Power | 750W @ +50C |
Features
- Unbeatable EVGA 7 Year Warranty and unparalleled EVGA Customer Support.
Specs
MAX Output | 24A | 22A | 54.1A | 0.5A | 3.0A |
649.2W | |||||
Combined | 110W | 649.2W | 6W | 15W | |
Output Power | 650W @ +50C |
Features
Specs
MAX Output | 22A | 22A | 45.8A | 0.5A | 3.0A |
549.6W | |||||
Combined | 110W | 549.6W | 6W | 15W | |
Output Power | 550W @ +50C |
