The EVGA GeForce GTX 1080 and 1070 FTW HYBRID cards are built from the ground up to be the best closed loop cooling solution for NVIDIA based graphics cards on the planet. It starts with power, our cards use our award winning FTW components, giving you the best power delivery, plus additional features like dual BIOS's, RGB Lighting, a 10CM fan and more.
On top of that, we took our award winning HYBRID solution, and cranked up a notch with a 10CM axial fan (delivering lower noise levels) and a dedicated memory cooling plate that makes direct contact with the water cooling block. Of course, the HYBRID water cooling solution gives you unbelievable GPU temperatures, sometimes cutting your GPU load temperatures in half! Best of all? The EVGA HYBRID cards need no maintenance, no filling, no hassle. All backed by EVGA legendary Warranty. The choice is simple, EVGA HYBRID products are truly water cooled perfection.
Features
Built on Pascal
The EVGA GeForce GTX 1080 HYBRID features the most advanced GPU architecture ever made, designed to be the engine of next generation gaming.
Hydro Performance
Without the Hassle
All in one cooling solution that is completely self-contained. No filling, no custom tubing, no maintenance. Just plug and play.
Sleek Looks
Intelligent wiring system and sleeved tubing make this one sleek cooler without the messy wires.
Copper Base Built for GPU's
A copper base that is BUILT for GPU's, the ONLY way to get the best temps possible.
Dedicated Memory Plate
A dedicated memory plate that makes DIRECT contact with the water cooling block. Giving the lowest memory temperatures possible.
Built in Radiator and Fan
Built in 120mm radiator and fan helps dissipate the heat keeping the GPU as cool as possible. Fan can also be swapped or customized.
FTW Features
10 Phase Power System with Dual BIOS gives you performance and features that go for the win.
Adjustable RGB LED
EVGA GeForce GTX FTW HYBRID
- CUDA Cores: 2560
- Base Clock: 1721 MHz
- Boost Clock: 1860 MHz
- 2-way SLI Ready
- Memory Bit Width: 256 Bit
- Memory Clock: 10000 MHz
- Memory Speed: 0.2 ns
- Memory Bandwidth: 320 GB/s
Key Features
- 10 Phase Power Design
- Adjustable RGB LED
- EVGA Double BIOS
- Microsoft DirectX 12 API
- NVIDIA® Ansel
- NVIDIA G-SYNC
- NVIDIA GameStream
- NVIDIA GPU Boost 3.0
- OpenGL 4.6 Support
- PCI Express 3.0
- VR Ready
- Vulkan API
- CUDA Cores: 1920
- Base Clock: 1607 MHz
- Boost Clock: 1797 MHz
- 2-way SLI Ready
- Memory Clock: 8008 MHz
- Memory Speed: 0.25 ns
Key Features
- EVGA Double BIOS
- NVIDIA® Ansel
- NVIDIA G-SYNC
- NVIDIA GameStream
- PCI Express 3.0
- VR Ready
- Vulkan API
