Now Available With 4GB of GDDR5 Memory
The EVGA GeForce GTX 960 delivers incredible performance, power efficiency, and gaming technologies that only NVIDIA Maxwell technology can offer. This is the perfect upgrade, offering 60% faster performance and twice the power efficiency of previous generation cards*. Plus, it features VXGI for realistic lighting, support for smooth, tear-free NVIDIA G-SYNC technology, and Dynamic Super Resolution for 4K-quality gaming on 1080P displays. The latest versions come outfitted with 4GB of high speed GDDR5 memory giving you higher texture qualities and better 4K performance!
The new EVGA ACX 2.0+ cooler brings new features to the award winning EVGA ACX 2.0 cooling technology. A Memory MOSFET Cooling Plate (MMCP) reduces MOSFET temperatures up to 11°C, and optimized Straight Heat Pipes (SHP) reduce GPU temperature by an additional 5°C. ACX 2.0+ coolers also feature optimized swept fan blades, double ball bearings and an extreme low power motor, delivering more air flow with less power, unlocking additional power for the GPU.
*Compared to GTX 660
EVGA ACX 2.0+ Cooling
* Versus Competitors' Dual Fan Solution.
** When GPU Temperature < 60°C
Why Double Ball Bearings?
Built with 4GB of High Performance GDDR5 Memory
4GB of High Performance Memory running at over 7,000MHz giving you higher texture qualities in games, better 4K gaming performance and optimized for the next generation of gaming.
EVGA ACX 2.0+ Means Better Overclocking
EVGA GeForce GTX 960 4GB
- CUDA Cores: 1024
- Base Clock: 1304 MHz
- Boost Clock: 1367 MHz
- 2-way SLI Ready
- Memory Bit Width: 128 Bit
- Memory Clock: 7010 MHz
- Memory Speed: 0.28 ns
Key Features
- dB Inverter
- EVGA ACX 2.0 Cooling
- EVGA Backplate
- Memory MOSFET Cooling Plate
- NVIDIA G-SYNC Ready
- NVIDIA GameWorks Technology
- NVIDIA GPU Boost 2.0
- NVIDIA MFAA Technology
- NVIDIA SLI Ready
- NVIDIA Surround Technology
- OpenCL Support
- OpenGL 4.4 Support
- Optimized Power Target
- PCI Express 3.0 x16
- Quick Switch Dual BIOS
- Straight Heat Pipes
- CUDA Cores: 1024
- Base Clock: 1279 MHz
- Boost Clock: 1342 MHz
- 2-way SLI Ready
Key Features
- dB Inverter
- EVGA Backplate
- NVIDIA SLI Ready
- OpenCL Support
- CUDA Cores: 1024
- Base Clock: 1127 MHz
- Boost Clock: 1178 MHz
- 2-way SLI Ready
Key Features
- dB Inverter
- NVIDIA SLI Ready
- OpenCL Support
EVGA GeForce GTX 960 Comparison Chart
Key Features
- Temperature Target Control
- Pixel Clock Overclocking
EVGA OC Scanner X – Featuring a brand new look and layout, this popular application has been updated to show all of the GeForce GTX 960 vitals. Learn more and download it here.
Key Features
- CPU Burn In Module
- Built-in log functionality
