EVGA SuperNOVA 850, 1050 GS and 1000 PS
Silence is Golden, and sometimes PLATINUM
EVGA is launching the new GS/PS PSU series. These power supplies follow the EVGA tradition of uncompromised power and performance, so we upped the ante and made it nearly SILENT. The GS/PS series of PSU’s offer superior performance, Gold and Platinum level efficiency and extremely low noise levels making it the perfect PSU for a sound conscious environment. These power supplies also feature ECO mode meaning the fan will run only when necessary further reducing noise level and power consumption! Backed by a 7 year Warranty and Japanese capacitor design makes this PSU the right choice for efficiency and noise level today, and will be with you well into tomorrow.
Features
- 80 PLUS Platinum certified, with 92% (115VAC) / 94% (220VAC~240VAC) efficiency or higher under typical loads
- Patented DC design minimizes voltage drops, impedance, maximizes efficiency and cooling to enhance overall performance
- 100% highest quality Japanese solid state capacitors ensure long-term reliability
- Quiet and Intelligent Auto Fan for nearly-silent operation
- High Amperage Single-Rail Design for maximum power and efficiency
- Over Power / Under Power / Over Voltage / Short Circuit / Over Current / Over Temperature protection built in
- EVGA's unparalleled Customer Support
- Ready for 4th Generation Intel Core Processors (C6/C7 Idle Mode)
- An outstanding 7 year Warranty
Specs
- OPP (Over Power Protection)
AC Input | 100 - 240 VAC, 12-6A, 50 - 60 Hz | ||||
MAX Output | 25A | 25A | 83A | 0.5A | 3A |
996W | |||||
Combined | 125W | 996W | 6W | 15W | |
Output Power | 1000W @ +50C |
Features
Specs
MAX Output | 25A | 25A | 87A | 0.5A | 3A |
1044W | |||||
Combined | 125W | 1044W | 6W | 15W | |
Output Power | 1050W @ +50C |
Features
Specs
AC Input | 100 - 240 VAC, 11-5.5A, 50 - 60 Hz | ||||
MAX Output | 25A | 25A | 70A | 0.5A | 3A |
840W | |||||
Combined | 125W | 840W | 6W | 15W | |
Output Power | 850W @ +50C |
EVGA SuperNOVA 850, 1050 GS and 1000 PS Academy
Single +12V Rail
A single +12V rail offers the best power output, rail stability and compatibility with the latest hardware. EVGA SuperNOVA 850GS/1050GS/1000PS provides up to 70A/87A/83A respectively on a single rail!
LLC Resonant Circuit Layout
Full DC to DC, LLC resonant circuit design improves efficiency.
Fully Modular
Fully modular designs allows every single cable to be removed from the power supply for ease of installation and removal. You can also leave off unnecessary cables to reduce case clutter and maximize case airflow.
NVIDIA SLI Ready
Run multiple NVIDIA graphics cards for the ultimate gaming experience. The SuperNOVA 850/1050 GS and 1000 PS gives you the power you need to drive these demanding systems and achieve the best overclocks.
Highest Quality Japanese Nippon Chemi-Con Solid State Capacitors
Teflon Nano-Steel Bearing
High quality Teflon Nano-Steel bearing ensures long life and nearly silent operation.
Gold Rated Efficiency
80 Plus certification ensures your power supply isn’t wasting power and turning it into excess heat. Under typical load this power supply is 90% efficient or higher.
Platinum Rated Efficiency
80 Plus certification ensures your power supply isn’t wasting power and turning it into excess heat. Under typical load this power supply is 92% efficient or higher.
